mnhim001
Jan 16, 2024Aspirant
VPN passthrough not working
Hi, I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it. Just recently, when connected to the VPN, I don't get any Internet or local access pass t...
- Jan 19, 2024
mnhim001,
I reverted back to V1.0.12.96_2.0.45 and the VPN is now working properly...
You might want to give that a try before jumping through a bunch of hoops for Netgear support...
mnhim001
Jan 19, 2024Aspirant
Reverting back to the previous firmware worked. Thank you for helping me troubleshoot.
Thank you for your suggestion, it worked.
c4rloco
Feb 02, 2024Tutor
I am also experiencing the same issue (VPN Passthrough is not working). I can connect with errors to the VPN but I cannot browse any website.
I opened the case# 48002888 in case this helps.
