mnhim001
Jan 16, 2024Aspirant
VPN passthrough not working
Hi, I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it. Just recently, when connected to the VPN, I don't get any Internet or local access pass t...
- Jan 19, 2024
mnhim001,
I reverted back to V1.0.12.96_2.0.45 and the VPN is now working properly...
You might want to give that a try before jumping through a bunch of hoops for Netgear support...
c4rloco
Feb 01, 2024Tutor
I am also experiencing the same issue (VPN Passthrough is not working). I can connect with errors to the VPN but I cannot browse any website.
I opened the case# 48002888 in case this helps.
