penguinpages's avatar
Jul 23, 2021
VPN RAX120 - Windows 10
  Trying to find RTFM for how to setup VPN.  I did the usual of enable link to no-ip.com   so my DNS for public IP does get set in the configuration client export.  I left the network acess to "auto...
  • michaelkenward's avatar
    Jul 24, 2021
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so there may be useful responses here, but there are subtle differences between RAX and bog-standard Nighthawk routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
