sonofdad
Feb 03, 2022Aspirant
VPN setup Nighthawk router
Is their a more definitive or updated instruction on enable Open VPN on a Nighthawk router than what is provided online by Netgear I'm trying to setup on a Nighthawk AX8 with up to date firmware, I s...
Kitsap
Feb 03, 2022Master
A couple of background issues. You cannot test your VPN connection from home while connected to Wi-Fi from the same router where your VPN server is running. Test from some location where you actually go through the internet to get to your router.
On an Android device before importing the profile, you must place the four configuration files in the top level of the memory on the main device. They cannot be located on an SD card or lower level directory on your main device.
The VPN applications on both Windows and Android generate detailed logs of the connection process. They might hold some information as to why a connection is not being made.
sonofdad
Feb 12, 2022Aspirant
Thanks for the info on Android I've moved the files from Downloads into what appears to be the most high level fold but still get the same error.
As for the Windows 10 device I had it using mobile hot spot in order to test the connection
- KitsapFeb 12, 2022Master
On the Android device after you moved the configuration files, you would need to delete and then re-import the profile. Attached is a screen snip of the file structure on my Samsung tablet. The only three stand alone files in the top level are three different ovpn profiles.
I personally have tried to connect through two or three different mobile hotspots, one stand alone device from Verizon and one or two from different iPhones. None were successful. Mobile hotspots and their capabilities are really carrier specific. Yet I have no problems connecting to the vpn through Wi-Fi at a restaurant, park, airport, neighbors house, etc.
- Razor512Feb 12, 2022Prodigy
For android, to import the VPN config, after configuring it in the router (esetting up DDNS if needed), and setting it to allow internet access if needed, and then enabling it and applying, then download the configuration file for smartphone.
It will come as a zip file. Unzip that file to a new folder, and then copy that folder to your smartphone. (the files in there need to be together in their own folder for best results).
Then using an app like openvpn connect https://play.google.com/store/apps/details?id=net.openvpn.openvpn browse to the folder and import the profile, the .ovpn file will read from the other 3 files to get the rest of the info that it needs. To test it, disconnect from WiFi and connect over LTE to see if the VPN server is working.
