sonofdad
Feb 03, 2022Aspirant
VPN setup Nighthawk router
Is their a more definitive or updated instruction on enable Open VPN on a Nighthawk router than what is provided online by Netgear I'm trying to setup on a Nighthawk AX8 with up to date firmware, I s...
sonofdad
Feb 12, 2022Aspirant
Thanks for the info on Android I've moved the files from Downloads into what appears to be the most high level fold but still get the same error.
As for the Windows 10 device I had it using mobile hot spot in order to test the connection
Kitsap
Feb 12, 2022Master
On the Android device after you moved the configuration files, you would need to delete and then re-import the profile. Attached is a screen snip of the file structure on my Samsung tablet. The only three stand alone files in the top level are three different ovpn profiles.
I personally have tried to connect through two or three different mobile hotspots, one stand alone device from Verizon and one or two from different iPhones. None were successful. Mobile hotspots and their capabilities are really carrier specific. Yet I have no problems connecting to the vpn through Wi-Fi at a restaurant, park, airport, neighbors house, etc.
