EphraimB
Jun 17, 2021Aspirant
Wake on Lan with RAX80
How do I enable wake on lan on my nighthawk RAX80 router?
- Christian_RNETGEAR Employee Retired
Hello EphraimB,
The RAX80 currently does not support this feature.
Regards,Christian
- EphraimBAspirant
Which routers do?
- NmouneimneApprentice
I have been able to use Wireless Wake-on-LAN in Windows 10 with my RAX80. Here are the steps I took.
1. Enable WOL and/or wake on USB in the bios;
2. I have my router issue a static IP to my computer;
3. Set up the Dynamic DNS Netgear service on the router;
4. Forward port 7 to the computer;
5. Finally, I wake it up "RemoteBoot" (iphone app). I enter in my router's IP address, Mac address, port 7, and DNS address.
Hope that helps someone.
- EphraimBAspirantSo I need port 7 and not port 9?
I used port 7. I do not recall if I tried 9 and it did not work. I did not need to forward both ports. However, you may need to try one then the other or both.
