EphraimB
Jun 17, 2021Aspirant
Wake on Lan with RAX80
How do I enable wake on lan on my nighthawk RAX80 router?
antinode
Jun 22, 2021Guru
> 5. Finally, I wake it up "RemoteBoot" (iphone app). [...]
If you're using a program which runs on some other system, then the
router itself is not really doing anything with WoL.
> So I need port 7 and not port 9?
You'd need to use whatever the WoL program needs you to use. But,
again, it'd be the WoL program which would be doing the WoL work, not
the router.
> Which routers do?
I know nothing, but I've never see WoL mentioned in the documentation
for any consumer-grade Netgear router. I seem to recall seeing reports
here of people using a Raspberry Pi with a WoL program. In that case,
too, the router would not be doing the actual WoL work.
Nmouneimne
Jun 23, 2021Apprentice
I forgot to mention, I believe windows 10 requires you to turn off fast boot for WOL to work.
- EphraimBJun 23, 2021AspirantI did that already
- NmouneimneJun 23, 2021Apprentice
Go into the device manager, select your network adapter, and make sure you have enabled both "Allow this device to wake the computer" and "only allow a magic packet to wake the computer."
