MrPoWeR
Nov 29, 2021Follower
Wake on Lan with (RAXE500)
How do I enable wake on lan on my nighthawk AXE11000 WiFi Router (RAXE500) router? Model: AXE1100 |Nighthawk AXE11000 (RAXE500)
Nov 29, 2021Guru - Experienced User
Maybe a better description of what you're trying to do would help.
the router itself shouldn't be going to sleep or need the wake on lan function.
- FURRYe38Nov 29, 2021Guru - Experienced User
It's possible that the user maybe referencing Wake-On Lan feature on a PC or device. Something that users may be able to enable on a supporting PC or device. Some routers had a Wake-On Lan port forwarding features back in the old days. Not sure of the RAXE or if any newer gen NG routers support this feature anymore. Wake-On Lan is a PC or device supported operation. I would check into the PC mfr or devices help and support information on if these products support WoL and how to enable it there.
