WaldoTrout
Dec 14, 2019Follower
wall mounting AX11000 RAX200 (Imperial Shuttle Special Edition) orienttion
All the guides say and show antenna positioning as vertically. then comes the "Imperial Shuttle" editions of the routers. (AX11000, AX6000, e.g. although my NetGear APP displays the router as "...
Mar 31, 2020Guru - Experienced User
you can see how i have mine setup in my signature
npugyp0k
Mar 31, 2020Aspirant
Oh, I see, so your RAX200 and Orbi are hooked up to the switch and work independently from each other. Cool, thx!
- plemansMar 31, 2020Guru - Experienced User
My orbi is in AP mode. So its going RAX----->switch------->orbi------->satellites.
- npugyp0kMar 31, 2020Aspirant
So RAX is not broadcasting a network...??
It is but mainly for testing purposes. My house doesn't get good enough coverage off 1 router and mesh supplies the best overal connection.
Plus running the RAX gets me familar with the AX devices/usage/scenarios. Its a bit overkill
