WaldoTrout
Dec 14, 2019Follower
wall mounting AX11000 RAX200 (Imperial Shuttle Special Edition) orienttion
All the guides say and show antenna positioning as vertically. then comes the "Imperial Shuttle" editions of the routers. (AX11000, AX6000, e.g. although my NetGear APP displays the router as "...
npugyp0k
Mar 31, 2020Aspirant
So RAX is not broadcasting a network...??
Mar 31, 2020Guru - Experienced User
It is but mainly for testing purposes. My house doesn't get good enough coverage off 1 router and mesh supplies the best overal connection.
Plus running the RAX gets me familar with the AX devices/usage/scenarios. Its a bit overkill
