Hyperflasch
Mar 08, 2020Follower
WAN Aggregation Rax120 and Fritzbox
Is there a possibility to bundle 2 Ports of the Fritzbox to get higher Bandwith ? The Ports of the Fritzbox are just 1 GB and i want faster connections by wire, cause my PC and AX got 2,5, GB Ports. T...
Mar 09, 2020Guru - Experienced User
which fritzbox do you have? Thats the key as if it doesn't have wan/lan aggregation, then you can't do what you're trying to do .
