Lb14
Jul 05, 2023Follower
WAN IP address changed by ISP
After a 10 hour outage by my ISP (Spectrum), my modem (ARRIS SURFboard SB8200) was assigned a new IP address when it went back online as service was restored. As a result, I am not able to connect to...
microchip8
Jul 05, 2023Master
There is no such option. And you don't have control over which IP your ISP will assign to your router.
Best you can do is to use a hostname and update the IP address
- michaelkenwardJul 05, 2023Guru - Experienced User
Does Anywhere Access fall over when the ISP changes the WAN IP address? Seems unlikely as this is always going to happen.
In that case MyNetgear does the connecting. It should work on the RAX50.
Then there is Netgear DDNS.
How do I set up Dynamic DNS (DDNS) on my NETGEAR router? | Answer | NETGEAR Support
