msvendsen
Apr 24, 2023Aspirant
WAN VLAN Tagging for Fiber ONT
Hello, I just had Brightspeed fiber installed this past week at my house. The install included them installing a Calix ONT in my house and then connecting their own router to that. The included router...
- Apr 26, 2023Thank you all, I didn't mention the c4000 at first and mentioned the calix ont because I wanted to connect the netgear directly to the ont using vlan tagging and was not going to use the c4000 at all, this shoud of worked but vlan wan tagging is not supported on the netgear. This forum helped me decide to use the netgear in ap mode, thank you!
Apr 24, 2023Guru - Experienced User
- msvendsenApr 24, 2023AspirantHello and thank you so much for the reply and advice! I have tried doing it like this, however whenever I name the VLAN and set the ID to 201, it has me select the ports to apply it to, it gives me every port but the WAN port to possibly select. I have attached a screenshot here for reference. Any other ideas? Thanks anyone for any help at all.
