msvendsen
Apr 24, 2023Aspirant
WAN VLAN Tagging for Fiber ONT
Hello, I just had Brightspeed fiber installed this past week at my house. The install included them installing a Calix ONT in my house and then connecting their own router to that. The included router...
- Apr 26, 2023Thank you all, I didn't mention the c4000 at first and mentioned the calix ont because I wanted to connect the netgear directly to the ont using vlan tagging and was not going to use the c4000 at all, this shoud of worked but vlan wan tagging is not supported on the netgear. This forum helped me decide to use the netgear in ap mode, thank you!
Apr 26, 2023Guru - Experienced User
https://www.manualslib.com/manual/2327484/Centurylink-C4000xg.html
https://www.quantumfiber.com/support/equipment/c4000-user-guide.html
msvendsen
Apr 26, 2023Aspirant
