murius
Sep 10, 2021Initiate
Want to upgrade home network
Upgrades to my network that I was thinking about getting but didn't know if they would help: AX2700 WiFi Cable Modem Router (CAX30S) Nighthawk® DOCSIS® 3.1 2.7Gbps Two-in-One Cable Modem + WiFi 6 ...
- Sep 10, 2021
The CM2000 is a solid modem.
Keep in mind it has a 2.5gig port.
The MK83 doesn't have a 2.5gig port so that'll be its limiting factor.
If you're only planning on going up to gig speed, the cm1000 is a solid choice.
Sep 10, 2021Guru - Experienced User
the CAX30 and the MK83 won't integrate together.
You can use them at the same time but they won't integrate and be part of a mesh together.
what speeds do you pay for?
If you're not looking for greater than gigabit speeds, I'd keep your current modem and just go with the MK83 system.
Much cheaper and you can always upgrade your modem if you increase your speeds down the road.
And you can add addional satellites if you need it down the road.
- muriusSep 10, 2021Initiate
My current internet is 500mbps now but may upgrade in the near future. I was also looking at this NETGEAR Nighthawk Multi-Gig Cable Modem CM2000 - Compatible with All Cable Providers incl. Xfinity, Spectrum, Cox | for Cable Plans Up to 2.5Gbps | DOCSIS 3.1
to replace my current modem for future growth.
I just want to make sure whatever I go to supports the current list of devices. The google mesh i have now I don't think is doing the job. The other issue was nighthawk vs the orbi as my router is in the basement but I need strong connections in the upstairs.
- plemansSep 10, 2021Guru - Experienced User
