murius's avatar
murius
Initiate
Sep 10, 2021
Want to upgrade home network
Upgrades to my network that I was thinking about getting but didn't know if they would help: AX2700 WiFi Cable Modem Router (CAX30S) Nighthawk® DOCSIS® 3.1 2.7Gbps Two-in-One Cable Modem + WiFi 6 ...
  • plemans's avatar
    Sep 10, 2021
    The CM2000 is a solid modem.
    Keep in mind it has a 2.5gig port.
    The MK83 doesn't have a 2.5gig port so that'll be its limiting factor.
    If you're only planning on going up to gig speed, the cm1000 is a solid choice.
