thebditch's avatar
thebditch
Weird connection status in Device Manager
Hi   I actively monitor my devices that are connected and notice that I see devices saying wired.  The latest being a Samsung TV in my master bedroom that has never been nor ever will be wired.  Is...
  • antinode's avatar
    antinode
    May 24, 2021
    > Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
       Firmware version?  Connected to what?
    > [...] I see devices saying wired. [...]
       Have you any wireless access points connected to the RAX200, or is it
    your only one?
    > [...] Is there a way to refesh the list [...]
       I've never seen a good explanation of how devices are added to or
    removed from the Attached Devices report on any of these routers.
    Complaints about those reports are not uncommon.
    > [...] I have checked IP addresses. [...]
       "checked"?  What's to "check"?  What did you expect to learn from the
    IP address of a client device?
    > [...] NMAP is often used as a hacker tool and I do not want any
    > malware.
       Nmap "is a free and open source utility"; it's a tool.  I would not
    expect there to be much (if any) demand for a commercial version, but
    you're free to look for one.  A keyboard "is often used as a hacker
    tool", too.  Did you plan to get rid of yours for that reason?
          https://nmap.org/
