cyberbiker
Jun 30, 2023Guide
What Does “6-Stream WiFi Router” Mean?
I want a WiFi router that can broadcast on at least 4 SSIDs. The lingo is a bit confusing. Does “6-Stream” in the Nighthawk® RAX50 AX6 6-Stream AX5400 WiFi Router mean it can have 6 SSIDs? https://...
- Jun 30, 2023
Stream means how many MIMO antennas are running 2.4 and 5Ghz at the same time. 6x6 would be what this means here.
The most you'll ever see out of a dual band is two SSID broadcasts. Tri band router you can get 3 SSID broadcasts. Broadcasts is the SSID name for the 2.4 and 5Ghz radio frequencies. Most of the time Smart Connect is a feature that combines the 2.4 and 5Ghz SSID names into one SSID Name broadcast for both 2.4 and 5Ghz frequencies.
cyberbiker
Jul 01, 2023Guide
I’m a retired senior who lives in a large house with 10 units. Some of my very senior housemates are not very IT savvy so I’m providing free WiFi service to all (and some Internet usage instruction) in hopes they find the access to knowledge and entertainment enjoyable.
The connected devices will be a mixture of smartphones, tablets, laptops and smart TVs — probably a total of fewer than 15 devices on the Guest SSIDs.
I need to retain one smart (2.4 & 5G) SSID for myself and have offered the Guest 2.4G and 5G SSIDs to everyone else using a single password.
Based on what you all have said, I guess I’ll plan to leave everyone else on the Guest 2.4G and 5G password protected SSIDs.
Thanks for the counsel.
My setup: Spectrum broadband > Spectrum DocSis 3.1 eMTA EU2251 Voice Modem > Netgear RAX50 AX5400v2
michaelkenward
Jul 02, 2023Guru - Experienced User
You should have used the tag cyberbikerhero given that self imposed task.
You are getting into the sort of territory where "business" equipment kicks in, the sort of thing they use in bars and places to provide wifi access for customers.
Wireless Access Points - NETGEAR
With that many people on the system, you might be able to persuade them to contribute to the cost of something that would give you more control over what is going on. If you don't mind being fall guy, you can then give yourself boss man rights.
If you get the right kit, you might be able to get away with no password for these less than savvy users. I have never understood why cafes, for example, insist on having complicated and meaningless passwords. (I have failed in my attempts to get our local pub to use something meaningful as a password.)
Once again, respect for taking on this role.
