Dhiren2005
Jul 30, 2020Follower
What is OFDMA
What is OFDMA???? Does it Reduce speed or increase it. And how to increase range and speed in the Router. What is the Best routers ip setting Thank you in Advance
schumaku
Jul 31, 2020Guru - Experienced User
Dhiren2005 wrote:
What is OFDMA????
https://kb.netgear.com/000059685/What-is-Orthogonal-Frequency-Division-Multiple-Access
OFDMA (and UL-/DL-MU-MIMO) is made to enhace the concurrent usage of wireless devices with different capabilities.
Range is given by the power "on air" (resricted by regulations) and the sensibility of the receivers.
Wi-Fi 6 is the first standard not designed for more speed - much more for multi-user/multi-device access.
What do you want to know?
