Fishon123's avatar
Fishon123
Follower
Jan 04, 2020
What should I get to replace my r7000!
What would be a good replacement for the t7000
I thought about getting the AX8 but when I hooked it up it does not seem any faster than the AX8
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Answers will depend on what you are trying to achieve.
    What's wrong with the R7000 that makes you want to change it?
    What features are missing?
    Where is its performance not as good as you would like?
    Or do you just want a shiny new router?
