Streamerman's avatar
Streamerman
What speed should I expect?
Just hooked up new AX2400 WiFi Router (RAX29) router. What speed should I expect coming out of this router if I have 1 Gig going into it?
  • FURRYe38's avatar
    Should see near 900Mbs or just over with ethernet speeds. WIreless, depending on devices support, 2x2 MIMO devices will tend to max out at round 500-700Mpbs.
  • plemans's avatar
    What wireless device are you testing on?
    Thats the key as different devices are going to give you different speeds.
    Do expect the speeds to drop of quickly with distance/obstruction/interference.
  • michaelkenward's avatar
    michaelkenward
    Wifi speeds are witchcraft, with too many variables to do more than guess.
    It might be worth a bit of background reading.
    Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
    @duckware knows their stuff and can bust a few myths and cut through marketing hype.
