ssssss
Jan 09, 2023Tutor
What's the current status of RAX120 in 2023?
Thinking of buying "Netgear Nighthawk AX12", mainly use as AP. But I read lots of bad review regarding rebooting problem. What's the current status on this? solid enough after firmware upgrade?
Jan 09, 2023Guru - Experienced User
so you'll see a lot of reports from them on here as this is the forum where people come with issues.
So you'll see it a lot of here.
but if you're looking for mainly an access point, why not just get an access point?
microchip8
Jan 09, 2023Master
The RAX120 is a waste for using it just as an Access Point. If you need that, just get an Access Point instead of a full-blown high-end router. It's overkill to get the RAX120 and use it as a simple AP.
- ssssssJan 09, 2023Tutor
plemans microchip8 For $200 range, you really can't get a good AP at this price. WAX615 only rated for AX3000 but weak cpu and memory.
- microchip8Jan 09, 2023MasterAn AP does not need top-of-the-class CPU and memory, that's reserved for routers that have to do a lot more than APs. All an AP has to do it forward to the main router.
Yes, but you get more for about same money, better cpu, better memory and antenna than pure AP device.
