ssssss
Jan 09, 2023Tutor
What's the current status of RAX120 in 2023?
Thinking of buying "Netgear Nighthawk AX12", mainly use as AP. But I read lots of bad review regarding rebooting problem. What's the current status on this? solid enough after firmware upgrade?
Jan 09, 2023Guru - Experienced User
If you really want the RAX120v2 then there is a patch that fixes the random reboot issues seen only on v2s.
