joe_wht
May 06, 2021Luminary
What's Wrong with RAX200 AX11000 ??? On my 3rd one ??
QUESTION .. At The END.. I'm on my 3rd Nighthawk RAX200, AX11000 ??? Why do they continue to GO OUT ? After a year or so.. they go out.. I'll reboot, Re-Add then they freeze up,. Tech Support ( ...
Christian_R
May 12, 2021NETGEAR Employee Retired
Hello,
Were you able to get in contact with our support team now or previously?
https://www.netgear.com/support/contact.aspx
Christian
- joe_whtMay 12, 2021Luminary
They took me through all the same tasks.
BUT we did get a smb : // 192 .1 6 8 . 1 . 2 6 to connect and I added it to my finder....
along with the AFP that I always used.. of coures I had to delete all my other AFP links
The SMB downloads MIGHTY FAST.. like my ReadyNAS always was with AFP.
My concern.... Isn't SMB Going out of style?? I'm thinking I've seen statements where
the ReadyNAS does not support it.. or it's updates or something.
..and why doesn't the ReadyNAS Unit it'self handle the speed transfering my files to my Hard Wired Laptop?
The only things I do not have Ethernet & Switch connected are my Wifi Security Cams which has no ethernet ports.
Christian, Thanks for the reply !!!
- Joe
