johnnysoulja
Oct 21, 2023Tutor
When I open youtube, there is a delay before the ad or content loads. This may be 15-30 seconds or
RAX75 When I open youtube, there is a delay before the ad or content loads. This may be 15-30 seconds or more. This happens regardless of if it is a computer or a mobile device on the wifi network...
- Oct 24, 2023
Any progress on this?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
michaelkenward
Oct 21, 2023Guru - Experienced User
johnnysoulja wrote:
RAX75
What's the firmware on the router?
Just YouTube? Everything else is OK?
johnnysoulja wrote:
Net straight into the Router. There is no modem.
What does that mean?
How does the Internet get to you? If it is a "campus" network there is chance that it has its own router.
johnnysoulja
Oct 21, 2023Tutor
What's the firmware on the router it is up to date
Just YouTube? Everything else is OK? just youtube
@johnnysoulja wrote:Net straight into the Router. There is no modem.
What does that mean? it's my home internet going right in to the router
- michaelkenwardOct 21, 2023Guru - Experienced User
Forgive me, I should have asked "what is the number of the firmware version"?
Far too often people turn up here claiming "the latest" only to discover that they have missed out a lot of updates.
There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface or with an app.
@johnnysoulja wrote:What does that mean? it's my home internet going right in to the router
Again, that misses out essential details. It does not tell us how the Internet gets to you.
What is "my home internet"?
What do you plug the RAX75 into? This often turns out to be a modem/router which can complicate matters.
- johnnysouljaOct 21, 2023Tutor
fw is v1.0.20.140
i do not have a modem my internet line plugs right into the RAX75- michaelkenwardOct 21, 2023Guru - Experienced User
johnnysoulja wrote:
fw is v1.0.20.140
There is no such thing for the RAX75.
Do you mean 1.0.10.140
johnnysoulja wrote:
i do not have a modem my internet line plugs right into the RAX75That still does not help.
What is at the other end of the wire that plugs into the RAX75?
Does it go into a socket in the wall? If so, that is what I described as a "campus" network. This can mean that somewhere down in the basement there is a big switch that sends the Internet out to lots of people.
If that is the case then who knows what that switch does? If it is a router, then your own router is trying to do the same thing. That can cause problems.
yes 1.0.10.140 sorry
the line runs outside in my garage to the Verizon FiOS internet box but i know it working good as I said I hooked up too different routers and YouTube works fine only the netgear is doing this.- michaelkenwardOct 21, 2023Guru - Experienced User
And that box is?
... but i know it working good as I said I hooked up too different routers and YouTube works fine only the netgear is doing this.Different routers respond to their local environment in different ways. Some routers are good at detecting that there is another router in the network and set their configuration accordingly. Others have a hard time.
The fact that you have swapped different routers in and out can also cause problems. Flailing around and randomly connecting things to a network is asking for trouble. It takes a systematic approach, and attention to detail, to get a network to run properly .... and to troubleshoot problems.
Is this is a new RAX75, then your best bet might be to return it and buy something that is more in keeping with how you like to do things.
We are now well into this conversation, and you still haven't answered important questions. You may not think that they matter, but that is where the problem starts.
