Brancy51
Jul 12, 2020Aspirant
When I use my Nighthawk app, it shows my router as "offline" connected locally". But I can search
When I use my Nighthawk app, it shows my router as "offline" connected locally". But I can search and use the web fine.
Brancy51
Jul 14, 2020Aspirant
The message was in the top right corner of the router screen on the iPad Negear App. Unfortunately, I couldn't let me household go without a solution for days. Right now, the Nighthawk is collecting dust in the attic. And Optimum's deceptive sales tactic has disrupted my Plan A. Altice said they would just give me a wireless cable box. Instead they showed up with a new combined router/modem. I'll see how this works. Maybe I'll try to setup Nighthawk as a secondary router.
I appreciate the help, but we're not going to be able chase this one down to resolution.
michaelkenward
Jul 15, 2020Guru - Experienced User
That won't work. You need tp put the Nighthawk thing into wireless access point mode. Or work out how to bypass (bridge) the new modem/router from your ISP.
