TIEfitrRAXE500
Aug 27, 2023Aspirant
When to use the 2.5G Multi-Gig Port on the Nighthawk® RAXE500 AXE11000 Tri-Band WiFi Router
Recently I have had installed through AT&T Fiber Optic internet. I am on the 2Gig plan; So far it has been even better than I even hoped for and when I bought and installed the Nighthawk® RAXE500 AXE...
Kitsap
Aug 28, 2023Master
A cat 6a Ethernet cable from your ONT to your RAXE500 is recommended.
If you install the Nighthawk mobile application on your phone or tablet, the internal test will provide data on the throughput from the ONT to the RAXE500.
Your router has Ethernet output ports rated at 1 Gbps. You would have to test load more than one simultaneously to check the output.
