RotaryGirl
May 22, 2025Aspirant
When will OFDMA scrambling of 5G be corrected for RAX42?
I'm not a patient reader to muddle though all OFDMA topics so I'll make mine new and simple. When I enable 5G OFDMA on my RAX42, all heck breaks loose if multiple devices (even just two) connect ...
- May 23, 2025
Good suggestion but RAX42 is old product now and Netgear won't answer questions (like 'Is this fixed in new products?') about it or the particular issue.
May 23, 2025Guru - Experienced User
Something to make contact with NG support about. NG doesn't post if or when new fixes or new FW is forth coming.
https://www.netgear.com/support/contact.aspx
RotaryGirl
May 23, 2025Aspirant
- FURRYe38May 24, 2025Guru - Experienced User
Probably not.
