sonny_E
Sep 08, 2019Guide
Where is NTP timezone setting on AX40? Sayd should be administrative area but nothing?
sonny_E
Sep 09, 2019Guide
Well, that is nice but in the manual on page 103 there is no option in the menu it points to.
michaelkenward
Sep 09, 2019Guru - Experienced User
What are you trying to change? Server? Time zone?
It is clearly here:
- Advanced
- Administration
- NTP Settings
in my router.
Different model, but it rarely moves, unless you have put the router into AP mode, in which case it is outside that device's control.
- sonny_ESep 09, 2019Guide
Not there:
This is all I have
firmware is V1.0.2.60_1.0.1
- VerbaetimSep 11, 2019Aspirant
I can not find it either, it says in the manual but there is no NTP Settings my time is 1hr off, I am PST and its an hour earlier am in in AK time.
Hardware Version R1.05
Firmware Version V1.0.2.60_1.0.1
GUI Language Version V1.0.2.60_1.0.0.12Select ADVANCED > Administration > NTP Settings.
The NTP Settings page displays.
5. Select your time zone from the menu.
6. If you live in a region that observes daylight saving time, select the Automatically
adjust for daylight savings time check box.
7. Click the Apply button.
Your settings are saved.
