peabody
Oct 06, 2021Follower
Where's the Firewall?
I just bought this router and got it setup, and I wanted to create a firewall rule (specifically to block all IP addresses in China), but search as I might, all I can find is how to do a stateful key...
DarrenM
Oct 12, 2021Sr. NETGEAR Moderator
There is no advanced firewall settings that can be adjusted by the user on the router. If you are looking for more router protection I suggest taking a look at Netgear Armor. https://www.netgear.com/home/services/armor/
DarrenM
