AmazingAbe
Aug 06, 2019Aspirant
Which one for aggregation feature
Hello, I need to buy a router to aggregate two internet connections (ethernet). Some friends told me that the Netgear Router WiFi Nighthawk AX12 AX6000 does that but I've read it is suggested fo...
michaelkenward
Aug 07, 2019Guru - Experienced User
Do you mean two completely different Internet services? Different logins and external IP addresses?
I don't think that is possible. Certainly not with consumer grade equipment.
AmazingAbe
Aug 07, 2019Aspirant
The AX12 AX6000 does that. It's not a matter of loggin in. If you have a cable you don't need to log in because the signar arrives from the provider router and enters into the Netgear via ethernet. I just want to understand if the "smaller" version of the moden can do it.
- michaelkenwardAug 07, 2019Guru - Experienced User
There is no Netgear AX12 that I can see. Do you mean RAX120?
If so, "aggregation" there means that it connects "two Gigabit LAN ports or use Multi-Gig 5G Ethernet as WAN port (configurable)".
The RAX80 also does "PORT AGGREGATION—Ability to aggregate two gigabit LAN ports for faster file transfers".
Not sure that this has anything to do with combining two different Internet sources. More a case of getting more speed out of one connection.
- AmazingAbeAug 07, 2019Aspirant
Hello, thanks for your reply.
As you can see from this link i'm referring to AX12 AX6000 and on the same page you can select the AX4 AX3000 or the AX8 AX3000
https://www.amazon.it/Netgear-Router-Nighthawk-Velocità-standard/dp/B07NCS58BK/?th=1
Maybe in Europe they have different names?
Thanks,
No. Look at the page on the link. See where it says "(RAX120)". That's the model number. The other stuff is wifi labelling. Just look at the picture of the different models.
But the answer is the same.
"PORT AGGREGATION—Ability to aggregate two gigabit LAN ports"
Good luck getting it to merge two WAN ports.
