AmazingAbe
Aug 06, 2019Aspirant
Which one for aggregation feature
Hello, I need to buy a router to aggregate two internet connections (ethernet). Some friends told me that the Netgear Router WiFi Nighthawk AX12 AX6000 does that but I've read it is suggested fo...
jjw001
Aug 13, 2019Tutor
I have been fighting with the AX4 for over three months. It is not stable. DO NOT waste your time with this device.
- michaelkenwardAug 13, 2019Guru - Experienced User
You mean RAX40? That's the modem number. It is Netgear's only AX4. But it helps to be clear.
- jjw001Aug 13, 2019Tutor
yes AX4 = RAX40.
- Christian_RAug 14, 2019NETGEAR Employee Retired
Hi jjw001 - We recommend you continue to work with our Support Team regarding your issue(s). If you need any assistance with getting in contact with support again I'd be glad to give a hand.
~Christian
