AmazingAbe
Aug 06, 2019Aspirant
Which one for aggregation feature
Hello, I need to buy a router to aggregate two internet connections (ethernet). Some friends told me that the Netgear Router WiFi Nighthawk AX12 AX6000 does that but I've read it is suggested fo...
michaelkenward
Aug 13, 2019Guru - Experienced User
jjw001 wrote:
I have been fighting with the AX4 for over three months.
You mean RAX40? That's the modem number. It is Netgear's only AX4. But it helps to be clear.
jjw001
Aug 13, 2019Tutor
yes AX4 = RAX40.
- Christian_RAug 14, 2019NETGEAR Employee Retired
Hi jjw001 - We recommend you continue to work with our Support Team regarding your issue(s). If you need any assistance with getting in contact with support again I'd be glad to give a hand.
~Christian- jjw001Aug 15, 2019Tutor
I have invested over 30hrs of my time chasing my tail with Netgear support and nothing has improved. Just more questions. I can’t keep wasting my time.
- michaelkenwardAug 15, 2019Guru - Experienced User
I see no suggestion that you have tried starting your own discussion on this hardware. Jumping on at the end of a running conversation may mean that your issue gets lost. (It also diverts people from trying to help AmazingAbe.)
We don't even know if aggregation, the subject of this discussion, is the problem that you are trying to fix.
You can reduce the time you waste, yours and others, by beginning with your own conversation. That could be quicker than dealing with Netgear support. But first you will have to explain what is going on with your RAX40. This isn't even the same hardware as the RAX120.
