AmazingAbe
Aug 06, 2019Aspirant
Which one for aggregation feature
Hello, I need to buy a router to aggregate two internet connections (ethernet). Some friends told me that the Netgear Router WiFi Nighthawk AX12 AX6000 does that but I've read it is suggested fo...
AmazingAbe
Aug 15, 2019Aspirant
BTW, anybody can suggest me any NETGEAR product that does what I need? Two separate lines from my ISP that I can join through another device... Thanks.
schumaku
Aug 15, 2019Guru - Experienced User
AmazingAbe wrote:BTW, anybody can suggest me any NETGEAR product that does what I need?
Don't think Netgear has any Broadband Load Balancing or Broadband Channel Bonding offerings.
AmazingAbe wrote:Two separate lines from my ISP that I can join through another device...
Talk to your ISP first - they might have offerings making two or more broadband links into a true single Internet connection - unless you are behind a pure low cost load balance approach.
- michaelkenwardAug 15, 2019Guru - Experienced User
AmazingAbe has been told that before.
Re: Which one for aggregation feature - NETGEAR Communities
The message doesn't seem to stick.
- AmazingAbeAug 15, 2019Aspirant
I'm just moving to a new house where the fiber is not yet arrived (it's mixed fiber/copper). To work I need to move a lot of GBs per day therefore I need speed to Upload/Download/Working remotely with colleagues at the same time. In my actual house I can do that because I have a fiber connection. The best idea I had for the new house is to spend more money (not less) to hope to have a better speed at least similar to the fiber connection.
- Christian_RAug 16, 2019NETGEAR Employee Retired
Hi AmazingAbe - You may find more info on setting up Ethernet Port Aggregation on the RAX120 on page 94 of the user manual linked below:
http://www.downloads.netgear.com/files/GDC/RAX120/RAX120_UM_EN.pdf
~Christian - schumakuAug 16, 2019Guru - Experienced User
Christian_R wrote:Hi AmazingAbe - You may find more info on setting up Ethernet Port Aggregation on the RAX120 on page 94 of the user manual linked below:
Sorry Christian, this is not what AmazingAbe needs. WAN port aggregation won't allow to combine multiple Internet connections or communication links. It's only to provide higher bandwidth to a single Internet connection, typically on Cable Modems supporting router WAN port aggregation.
