AmazingAbe
Aug 06, 2019Aspirant
Which one for aggregation feature
Hello, I need to buy a router to aggregate two internet connections (ethernet). Some friends told me that the Netgear Router WiFi Nighthawk AX12 AX6000 does that but I've read it is suggested fo...
Christian_R
Aug 16, 2019NETGEAR Employee Retired
Hi AmazingAbe - You may find more info on setting up Ethernet Port Aggregation on the RAX120 on page 94 of the user manual linked below:
http://www.downloads.netgear.com/files/GDC/RAX120/RAX120_UM_EN.pdf
~Christian
schumaku
Aug 16, 2019Guru - Experienced User
Christian_R wrote:Hi AmazingAbe - You may find more info on setting up Ethernet Port Aggregation on the RAX120 on page 94 of the user manual linked below:
Sorry Christian, this is not what AmazingAbe needs. WAN port aggregation won't allow to combine multiple Internet connections or communication links. It's only to provide higher bandwidth to a single Internet connection, typically on Cable Modems supporting router WAN port aggregation.
