Burdell
Apr 09, 2021Tutor
Why can't I log in to my RAX45 Router to change the wireless channel?
Anyone know why I can not log in to my Router using the IP adress 192.168.1.1 to change the wireless channel? The log in gets stuck everytime and is unable to connect. Im using a macbook. Does not...
Apr 10, 2021Guru - Experienced User
Have you tried a different browser?
What modem do you have?
Is it a modem/router combo device? It can cause a double nat.
Many times the router will change its default ip address to 10.0.0.1 if it recognizes its in a double nat.
- BurdellApr 13, 2021Tutor
Hi Plemens...Update on not being able to change wireless channel on my Netgear ax45:
Used my wife's computer..Used Chrome as browser..but what got me in was using the
10.0.0.1 IP adress. So all is well..Thanks agan Plemens! You are on it sir.
- plemansApr 13, 2021Guru - Experienced User
Glad it worked!
If you mark it solved, it might help the next person with your issue
