Burdell
Apr 09, 2021Tutor
Why can't I log in to my RAX45 Router to change the wireless channel?
Anyone know why I can not log in to my Router using the IP adress 192.168.1.1 to change the wireless channel? The log in gets stuck everytime and is unable to connect. Im using a macbook. Does not...
Burdell
Apr 13, 2021Tutor
Hi Plemens...Update on not being able to change wireless channel on my Netgear ax45:
Used my wife's computer..Used Chrome as browser..but what got me in was using the
10.0.0.1 IP adress. So all is well..Thanks agan Plemens! You are on it sir.
Apr 13, 2021Guru - Experienced User
Glad it worked!
If you mark it solved, it might help the next person with your issue
