WhyDoINeedAnAcc
Jan 12, 2025Aspirant
Why do I need an account to configure my router?
Why in the absolute heck am I being told I need to have a NETGEAR account in order to access the management portal (192.168.1.1) for my router? This is absolutely ridiculous to me. On top of tha...
- Jan 12, 2025
Disconnect the router from the ISP modem.
Factory reset the router and setup from scratch with a ethernet connected PC to the back of the router:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Once setup, connect the router to the ISP modem.
WhyDoINeedAnAcc
Jan 13, 2025Aspirant
It ended up eventually just automatically bypassing the registration / login after failing ('Something went wrong' spam) about 12 times. I understand wanting to make the process more user-friendly for people who want to plug it in and have an app do everything, but they've made everything a lot more convoluted and unnecessarily obtuse, especially when the app / registration just doesn't work at all. Thanks for the follow-up.
Jan 13, 2025Guru - Experienced User
The seems to be a bug in current version of FW that causes this. All that was needed was to disconnect the router from the ISP services, factory reset and setup from scratch with out it connected, once at the home screen, then connect up the router to the ISP sevices.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
