Retired_Member
Dec 24, 2023why does wifi OFDMA degrade performance so badly?
my concern is with two PCs, filesharing to each other, both on the same wifi channel. I would upload a clear well-composed video illustrating it, but this forum doesn't support it. so I expect n...
michaelkenward
Dec 25, 2023Guru - Experienced User
You are using some Netgear hardware?
You seem to have come up with a self diagnosis of whatever your problem might be. It is usually better to start with describing the problem.
Is this it?
What is that telling us about your problem? It is too slow? It fails? Something else?
