Retired_Member
Dec 24, 2023why does wifi OFDMA degrade performance so badly?
my concern is with two PCs, filesharing to each other, both on the same wifi channel. I would upload a clear well-composed video illustrating it, but this forum doesn't support it. so I expect n...
Retired_Member
Dec 25, 2023- Retired_MemberDec 25, 2023
- michaelkenwardDec 25, 2023Guru - Experienced UserEmbedded pictures have to be approved. It may take some time before they show up. Attachments go through immediately.
it's not urgent.
my Xfinity XB8 gateway is working fine in the meanwhile.
I'd like to replace it with something better.
but I don't think any Netgear equipment exists presently that justifies replacing it.
that would've been my next question.
- schumakuDec 25, 2023Guru - Experienced User
These are about the performance numbers you can expect from a modern WiFi 6 router - as simple as that:
Appears there is a bigger problem on the RAX70 installation. Not that I expect some more than 950 Mb/s speed (like the almost symmetrical 2 Gb up and downlink speed), the limit is here on the RAX70 with "just" a GbE WAN port, and GbE LAN ports), something in the range of 950 Mb/s up and down is feasible without massive interferences or concurrent load on the wireless channels.
Completely buffed about the poor performance numbers on the RAX70, including 160 MHz bandwidth and a decent 802.11ax platform... and I have not talked about the odd non-standard user accessible controls for OFDMA (undoubted default for WiFi 6 and up).
A modern high-end router with a MultiGig WAN can provide similar numbers like this XB8. Yes, this makes it questionable if there is a future in middle-class routers - an are where the industry is massively loosing market share.
Difficult to replace a modern carrier CPE nowadays - excellent from what I see here. Nothing in the ~250 USD range for now anyway, worth to pay a monthly rental on it.
Sorry Netgear: A lot of homework for you these Christmas days of 2023.a
