Compumind
Apr 24, 2023Tutor
Why I am having problems with an NVMe SSD USB enclosure hanging off the RAXE500 USB port?
Hi all - Using a portable HDD presents no issues. However, I have a Sabrent NVMe USB 3.1 enclosure that has a 2TB NVMe in it. Then it is connected via a standard USB cable to the back of the RAX...
michaelkenward
Apr 24, 2023Guru - Experienced User
Good luck.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
I have no idea if your drive would hit the dreaded SMB issue:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
