Compumind
Apr 24, 2023Tutor
Why I am having problems with an NVMe SSD USB enclosure hanging off the RAXE500 USB port?
Hi all - Using a portable HDD presents no issues. However, I have a Sabrent NVMe USB 3.1 enclosure that has a 2TB NVMe in it. Then it is connected via a standard USB cable to the back of the RAX...
Apr 24, 2023Guru - Experienced User
the router doesn't install drivers so if the nvme drive or enclosure needs one, it'll create issues
- michaelkenwardApr 24, 2023Guru - Experienced User
Yes, but if Windows needs drivers, like many other USB devices, once installed shouldn't the thing work on the network?
Isn't that a red herring?
- CompumindApr 24, 2023Tutor
Netgear did not think this through, amongst other things.
If they request some technical information form me, I'll gladly provide it.
Poor USB implementation.
