Compumind
Apr 24, 2023Tutor
Why I am having problems with an NVMe SSD USB enclosure hanging off the RAXE500 USB port?
Hi all - Using a portable HDD presents no issues. However, I have a Sabrent NVMe USB 3.1 enclosure that has a 2TB NVMe in it. Then it is connected via a standard USB cable to the back of the RAX...
michaelkenward
Apr 24, 2023Guru - Experienced User
plemans wrote:
the router doesn't install drivers so if the nvme drive or enclosure needs one, it'll create issues
Yes, but if Windows needs drivers, like many other USB devices, once installed shouldn't the thing work on the network?
Isn't that a red herring?
Compumind
Apr 24, 2023Tutor
Netgear did not think this through, amongst other things.
If they request some technical information form me, I'll gladly provide it.
Poor USB implementation.
