Peter_lgy
Aug 08, 2019Aspirant
Why i can't disable the implicit beamforming on RAX120?
In the advance wireless configuration area of RAX120 , I can only enable or disable mu-mimo ..However for RAX80, I can enable or disable implicit beamforming . What does that mean? On RAX120 ,the ...
Peter_lgy
add the pic from rax80.
When i use RAX120,the option disappeared。
Christian_R
Aug 13, 2019NETGEAR Employee Retired
Hello Peter_Igy - Thanks for your post and a screenshot. You can find more information about Implicit Beamforming in the article linked below. Would you also mind providing the firmware version the RAX120 is currently on.
Thanks,
Christian
- Peter_lgyAug 16, 2019Aspirant
Thanks Christian!
I have read the article you told me. Yes, other routers can disalbe the implicit beamforming such as RAX80. There do exist the check box. However on RAX120 NO.
So i am puzzled if RAX120 doesn't support implicit beamforming or just won't let the customers change the function? Can you tell me? Thanks a lot!
The firmware i have updated to v1.0.1.90.
- Christian_RAug 16, 2019NETGEAR Employee Retired
Peter_Igy,
Sure thing! Beamforming is supported on the RAX120 however, there is no option to disable the feature in UI.
~Christian
- Peter_lgyAug 18, 2019Aspirant
Thanks a lot, Christian!
I know beamforming is mandatory in 802.11ax.
So implicit beamforming is needless. Am I right?
