thetechlady
Oct 25, 2022Aspirant
Why is my new router saying every site is unsafe?
I just installed a new RAX10, which was a pain to install, unlike other routers I have owned. Now, it is finding every new site that I try to visit is unsafe. When I say proceed anyway, it has been t...
michaelkenward
Oct 26, 2022Guru - Experienced User
Your router isn't likely to get in the way of your browsing. A more likely source of this intrusion is the browser you use, or possibly your operating system. Tried a different browser?
What is the exact message that you see?
When I say proceed anyway, it has been taking me to the router sign-in. When I sign in, I am presented with ads for Netgear support for about $79.
That is suspicious. What are you asked to sign into? The address?
What is this $79 supposed to provide? Netgear does try to push its Armor security service, but that isn't something that you should see in normal operation. It can get in the way when you try using the Nighthawk app for the first time.
That is also not typical and makes me suspect that something went wrong when you set up this thing/
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
cybot
Oct 29, 2022Luminary
I just got a new RAXE500 aand saw the same thing. I think it has something to do with the routers internal clock. but don't quote me on that. by the time i finished setting up the router settings, it had gone away. i think the warnings can be safely ignored as long as you only visit well known sites. in my case one of those warnings was handed out for this site, which was kinda funny if you ask me.
- Razor512Oct 29, 2022ProdigyIf another router is having the same issue, and if the router is fully set up, then chances are that the issue is something else.
While the router will get its time from an atomic clock server, it defaults to GMT-8 as the time zone, though since routers use self signed certificates anyway, they will never be trusted by default.
On the other hand on client devices, a timezone that is too far off of your current one, can cause security certificate issues since certificate management has gotten more strict over the years and the default behavior has become to be extremely sensitive to time. The only time you will encounter security warnings is if you have security software that doesn't k ow how to handle router setup page redirects. On rare cases, you can encounter a bad anti-virus install where the software fails to install its own root certificate, since for them to be able to scan that traffic, they need to have a root certificate on to avoud causing the browser to freak out when it intercepts the encrypted traffic.
The RAXE500 doesn't mess with WAN traffic outside of the initial setup, unless you enable the armor service, which will intercept known malicious DNS requests.
If possible, double check the time on your PC, as well as look at the details of any SSL errors to see the details about what certificate is being used.- cybotNov 04, 2022Luminaryin my case for some reason the raxe500 defaulted to London time. I am on the West coast of USA, so there was a big time difference that the router would have been reporting. issue went away after I setup the router (and fixed the clock setting). setting the router to PST fixed it for me
