gfs10
Jan 15, 2021Follower
why is the wifi strength of RAX120 so weak
i have my router sitting on top of a bookcase in the living room. no blockage, I loose strength at about 30 foot and need to add range extenders. Iam updated on all patches but quality and speeds se...
Christian_R
Jan 20, 2021NETGEAR Employee Retired
Hello gfs10,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
