p0se1d0nX
May 10, 2022Star
WHY is There Not a 160MHz option for 5GHz? (RAXE500)
Considering it’s their premium/flagship router retailing at $600 - how come 160MHz channel bandwidth is not available for 5GHz Wi-Fi (unlike other routers from other brands)??? Is this something th...
harryjones
May 10, 2022Initiate
Some newer routers, especially the high-end Wi-Fi 6 routers, are using 160MHz channels at 5GHz to achieve really impressive speeds. However, for many people and their wireless devices, this speed is not accessible.
p0se1d0nX
May 10, 2022Star
Hi. I’m in the US. In the web gui (advanced settings) under Wireless > 5GHz, it only shows 80 MHz wide from the selection. Don’t see 160MHz.
I have the latest firmware from a few days ago and have already performed a factory reset FWIW. Thanks
- plemansMay 10, 2022Guru - Experienced User
Not sure where your seeing that. (screensnip or shot might help)
The section where you select speeds "up to ****" is what sets the channel width.
When its set at "up to 4800mbps" thats the 160hz wide channels.
- p0se1d0nXMay 10, 2022StarI will add a screenshot when I head home on log-on to the router interface.
