p0se1d0nX
May 10, 2022Star
WHY is There Not a 160MHz option for 5GHz? (RAXE500)
Considering it’s their premium/flagship router retailing at $600 - how come 160MHz channel bandwidth is not available for 5GHz Wi-Fi (unlike other routers from other brands)??? Is this something th...
May 10, 2022Guru - Experienced User
Not sure where your seeing that. (screensnip or shot might help)
The section where you select speeds "up to ****" is what sets the channel width.
When its set at "up to 4800mbps" thats the 160hz wide channels.
p0se1d0nX
May 10, 2022Star
I will add a screenshot when I head home on log-on to the router interface.
