KangHH12
Nov 28, 2022Aspirant
Why Netgear disabled Wpa2/Wpa3 mixed mode on Rax38v2?
Wpa2/Wpa3 mixed mode disappeared on my Netgear Rax38v2 firmware is latest.. V1.0.11.112_2.0.77 It was available on Rax40v1 but in Rax38v2 It disppear I wonder if there is a plan to support i...
- Nov 28, 2022
Possible that NG hasn't implemented this on this model router yet.
Nov 28, 2022Guru - Experienced User
There a picture of this?
Did you factory reset and setup from scratch to be sure after you updated FW?
What do you see if you downgrade the FW on the RAX38 router?
KangHH12
I've never downgraded so I don't know what I'm seeing
After receiving the router, it was already the latest firmware, and it was initialized and set up
Which picture do you need?
