strykerzr350
Jun 04, 2022Guide
Why no output LAN 2.5GBE port on the RAXE500?
Something that bothers me to get 1440mbps speeds with Xfinity is for me to have a router and modem with 2.5 GBE port. So when I bought the RAXE500 I thought I would have a second LAN 2.5 GBE port, wh...
Jun 04, 2022Guru - Experienced User
1. Multigig ports are expensive. its why its rare to have on devices. The specs list what ports there are.
2. to see mutligig speeds, you can use lan port aggregation for wired connections How do I set up LAN Ethernet port aggregation on my NETGEAR Nighthawk router? | Answer | NETGEAR Support
Or you can see those speeds if you're wireless device has the capability. I've hit 1300mbps over a 6g and 5g connection. But you have to be close to the router and using a 2x2 160hz connections.
strykerzr350
Jun 04, 2022Guide
The manual I downloaded on the support page was a little vague for me at least, I have no problem using LAG to get those speeds as I would only want my desktop getting that.
I have no devices right now that would take advantage of the 6 Ghz wifi signal at this time.
Do you have any recommendations for link aggregation network cards?
